Spring in collumn that locks steering wheel...
Old Jan 1, 2002 | 04:08 PM
R.O.B.'s Avatar
I am replacing the collar in my steering wheel, because of it being broken by theft. The little spring that works the rod to lock the steering wheel, how does it hook up? I know it bolts in at the bottom, and the top raps around the locking rod, but what gives it the tension to make that locking rod work? Pics would be great!
Old Jan 1, 2002 | 05:13 PM
Vader's Avatar
ROB,
Would this help?
Old Jan 1, 2002 | 06:50 PM
R.O.B.'s Avatar
Excellent pic Vader, yet I did manage to figure it out before your reply. BIG problem now, as I was reassembling it, something came loose. I was just ready to put on the horn button, and clip it with the lock ring, and something slipped inside, and now the center shaft moves up/down and side/side. I removed the bearings, regreased, and put back in, but its still loose. What happened???
Old Jan 1, 2002 | 10:12 PM
wuter's Avatar
this happen to me too, it was easy to fix, just temporarily bolt the steering wheel on and pull on it while trying to center the shaft.
Old Jan 2, 2002 | 11:47 PM
R.O.B.'s Avatar
You make it sound like the shaft got bumped in to far and slipped out of something. Don't know, but thanks, I'll try it. Won't get a chance to work on it again until Saturday probably.
morrow
Jan 13, 2024 12:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
86CamaroDan
Sep 29, 2015 10:08 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
