Intermittent starting issues with 383 stroker
Old Jun 11, 2017 | 01:59 PM
71Stingray's Avatar
Want a title? Post!
383 stroker in '71 Stingray. It has a 650 Edelbrock carb with HEI ignition? It runs good for the most part but now it tuns over but won't start. It has happened a couple of times over the last 6 months but if I let it sit for a couple hours it would start. Now it won't fire...any ideas? Thanks , Brian
Old Jun 11, 2017 | 02:45 PM
Ja85z28's Avatar
Axle/Gears: 4:10
Re: Intermittent starting issues with 383 stroker
Fuel or spark, because you're losing one. Tell us about your ignition system.
Good Luck
Old Jun 11, 2017 | 02:51 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
you might want to use a spark tester next time it fails to start. It could be a faulty icm or pu coil.
Old Jun 11, 2017 | 03:44 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Will it start fine if the engine is "cold" but not when you are trying to start it when it's "hot?" Or it is a true intermittent that sometimes it wont start cold and sometimes it won't start warm? Also, once it starts does it run perfectly normal?
92 "ODESSA" RS
Jun 20, 2017 12:48 PM
Gmwctech
Jun 9, 2017 10:54 PM
383_bowler
Jun 8, 2017 09:14 PM
jaweiss
May 23, 2017 07:10 PM
