engine rough running low to midrange rpm
Old Jun 17, 2017 | 11:30 AM
DPW's Avatar
DPW
1992 305c.i. TPI installed new fuel pump idle OK...High RPM good under acceleration, but Major bogging down i. e. fuel starvation at majority of midrange RPM. Please help! DP
Old Jun 17, 2017 | 02:31 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: engine rough running low to midrange rpm
How old are your O2 sensors? Might try unplugging it, and see if the problem goes away.
Old Jun 17, 2017 | 08:16 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Was this the original TPI? Some of the earlier units had injectors that today's gas will mess up and then cause poor light acceleration and cruising smoothness due to lean out.
Old Jun 17, 2017 | 08:38 PM
DPW's Avatar
DPW
Thanks....All TPI injectors were replaced 3000 miles ago. Worked great until fuel pump went bad and was replaced OEM. Nothing but fuel starvation like symptoms ever since!
apie2546
Jan 3, 2017 01:18 PM
malachilou
Oct 12, 2016 01:43 PM
Ivekora
Oct 6, 2016 10:24 PM
jobryan26
Car Audio
21
Sep 11, 2002 12:26 AM
Brandog87GTA
Aftermarket Product Review
Sep 9, 2001 06:56 PM
