How much power can i make
Old Jun 21, 2017 | 06:25 PM
KingHD's Avatar
Car: 1987 Camaro
Engine: 350 HO 360whp
Transmission: Borg-Warner T5
i was wondering if i could get a general idea on how much power i could make on my stock block before getting an entire new block Thanks.
Engine: jegs 350 H.O
Specifications:
  • Engine Type: Chevy Small-Block V-8
  • Displacement: 350ci
  • Bore x Stroke: 4.000'' x 3.480''
  • Block: Cast-iron with four-bolt main caps
  • Crankshaft: Nodular iron
  • Connecting Rods: Powdered metal steel
  • Pistons: Cast-aluminum
  • Camshaft Type: Hydraulic flat tappet
  • Camshaft Lift: .435'' intake / .460'' exhaust
  • Cylinder Heads: Vortec Iron; 64cc combustion chambers
  • Valve Size: 1.94'' intake / 1.50'' exhaust
  • Compression Ratio: 9.0:1 nominal
  • Rocker Arms: Stamped steel
  • Rocker Arm Ratio: 1.5:1
  • Flexplate: 12.750''
  • Recommended Fuel: Premium pump
  • Ignition Timing: 34° Total @ 4000 rpm
  • Maximum Recommended rpm: 5100
  • Balanced: External
Old Jun 21, 2017 | 09:51 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: How much power can i make
Stock 2 bolt main? I'd say maybe 600 hp depending on rpm. Caps will walk with alot of power and or rpm. Internals will need to be strong. At very least good rods.
Old Jun 21, 2017 | 09:57 PM
JA411's Avatar
Don't worry about the power, quest put together a good working package. That's what it's all about.
Joe
Old Jun 22, 2017 | 12:52 AM
KingHD's Avatar
Car: 1987 Camaro
Four bolt main rpm limit is 5700 for now
Old Jun 22, 2017 | 07:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You can do studs on the mains for more strength but i have seen guys make well over 700-800 hp on stock block with boost. I made 600-650 on spray on my old 4 bolt 383. Good crank and rods helps.
If you hard fill the block i have seen some guys push near a 1000 hp with turbos. All depends
Block is generally good for most hardcore na street setups and mild boost/nitrous use
Old Jun 22, 2017 | 03:16 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have twisted that same shortblock 6,200 rpm in my 1997 Express van.
Once you upgrade the valve springs and cam it will scream even with the stock heads.
Old Jun 23, 2017 | 12:18 AM
KingHD's Avatar
Car: 1987 Camaro
i was planning on cam swapping and putting scorpion rockers, ported heads, and what valve springs should i go with.
Old Jun 23, 2017 | 07:02 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You could squeeze a good bit of power out of those stock vortec heads with a hyd roller swap. Something decent size and a ported dual plane intake. Rev to 6000-6200.
If you head swap for bigger heads and intake, i'd spin it to 6500
Old Jun 23, 2017 | 01:54 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I had a Lunati version of the LT4 Hotcam called the Bare Bones. It had similar specs to the Hotcam and made great HP and TQ with great street manners.
Old Jun 23, 2017 | 02:02 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Ran that cam in a big tube tpi afr 180 head L98. Awesome little street cam
