need advice.. how to stay with an LS1?
Old Jan 1, 2002 | 09:38 PM
rezinn's Avatar
I have an 87 iroc, it's a 305 with ported aluminum L98 heads, LT4 cam, roller rockers, edelbrock base, ported intake, coated edelbrock headers, borla catback, and a lot of other mods. I just raced my brothers 2000 z28 and the race was pretty even up to 70(about six seconds). At the beginning I pull ahead by a nose at about 30, then he catches up and we are dead even at 65, but then he just starts pulling more and more. By 80 he has a whole carlength on me.
What is it going to take to increase my topend performance enough to take him? More cubes? I was already planning on putting a larger block in this summer.. I know my mods will work pretty well on a larger engine, except the headers and the tpi are probably hurting me. Any advice on how to win?
Old Jan 1, 2002 | 09:53 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
From what I know about the LS1.
I can tell you they pull hard 1/8th mile and up... as was shown to you.
They are ranked at 305 hp, but many times pull closes to 305-310 to the rear. (340 or so to crank)
Autos usually have 104-106 trap speeds while M6s have 106-109 trap speeds.
I'm not quite sure how your going to beat him, I'm surprised you did as well as you did. What does your car run in the 1/4?
If I had to pick something, I'd say your right... larger cubes help, and getting rid of the TPI setup and maybe miniram or superram?
Nitrous never hurts either?
Old Jan 1, 2002 | 10:08 PM
rezinn's Avatar
Going to the track for the first time on the 12th, so I have no real times atm. I hope to have a new torque converter installed by then...and unless I can find a helmet I'll only get one run in. I had thought about the nos.. but I'd rather stay away from it. Would be nice to surprise some people though. Thanks for the input.
Old Jan 2, 2002 | 01:34 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Your gonna need at least 350 if u want to run against them N/A. For the 305 theres always S/C's and T/C's though.
Old Jan 2, 2002 | 01:49 AM
Jester's Avatar
Ditch the 305. You'll never keep up NA. You can keep up if you use a power adder...to a stock LS1 anyway. The problem is some of them do mods too I've heard...but that might just be a vicious rumor
Plan on at least a 350 (but the more the merrier), with a minimnum 190cc head and healthy cam. And ditch the long runner setup.
Old Jan 2, 2002 | 02:04 AM
rezinn's Avatar
This LS1 has a whisper lid, borla catback, and tb coolant bypass.. I put it all on myself
I will ditch the LTR setup.. how many cc's are these aluminum L98 heads stock?
Old Jan 2, 2002 | 02:20 AM
Jester's Avatar
150ish I believe..maybe 16x. I have the numbers somewhere but I don't feel like digging them up. For comparison..LS1 heads are over 200cc stock.
Old Jan 2, 2002 | 02:43 AM
rezinn's Avatar
If they are 150-60ish stock, how large could you make them with a lot of porting? They had an 800 dollar port job a while ago, I picked them up afterwards. They seem to flow pretty well atop my bore-deficient block.
sheachopper
Jul 31, 2019 11:27 AM
lewandom
Oct 1, 2015 08:15 AM
