Recommendations for 1989 IROCZ 350 rebuild that passes smog.
Old Jul 24, 2017 | 02:57 AM
Clements408's Avatar
Car: Son drives 1989 IROCZ
Engine: 5.7L TPI, AFR 195, L98
Transmission: 6 spd manual
Axle/Gears: Stock
Looking for recommendations on Cam selection and compression target to maximize horsepower and torque but still able to pass California smog inspection.
Engine specifics:
1. Accel Ho Flow lower intake. CARB exempt.
2. A,S& M high flow tubes. CARB exempt.
3. AFR 195 Aluminum heads (part# 1034) CARB exempt.
4. Forged pistons
5. Stock crank, and rods
6. Comp cam: recommended part numbers as a "great fit": 08-412-8, 08-501-8, 08-465-8, 08-302-8, 08-304-8.
7. Edelbrock 6872 shorty headers. CARB exempt.
8. L98 stock block.
Transmission will be a 6 speed T56.
Would like to hear from those who have re-built similar motors in California and passed smog.
