what did you do to your thirdgen today?
#801
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
Re: what did you do to your thirdgen today?
bought a GTA,it was WAY cheaper than buying individual parts,problem is now i have 2 third gen firebirds in white.
do i keep both? im thinking i just might 5.0/5 speed and an L98/auto ,why not?
#802
#803
bought a new heater control valve today to replace mine. its leaking and in this heat I cant afford to lose any coolant. edit- at 11pm I got stir crazy and went out and put on the heater control valve. I love a quick easy job. the vacuum line that attaches to the top of it is broken. im going to look and see how that routed and my connect the two ends with heat shrink instead of replacing it. we will see. I hope my coolant leak is now fixed. need to flush my coolant soon. its pretty nasty looking.
#804
I have been working on my a/c. its cooling very well but it isn't blowing as hard as I feel it should. I read that a lot of these cars will get clogged with leaves and debris behind the blower motor. I hoped that was what was causing my weak cfm. I removed the blower motor to have a look and it was pretty clean in there. a couple of leaves but no way it was blocking flow. the motor appears to be factory. I decided to replace it. its working but after 27 years it has to be worn out. I bought the replacement for $35 and will install it tomorrow. I really hope this adds some flow.
#805
Car: 1986 trans am
Engine: 305/350
is there a higher rated cfm blower/motor of a similar size that would give a reasonable boost without being too much?
#806
I may have possibly cleaned the interior and exterior glass for the first time in over 10 years of ownership ... I can't wait to drive it in the sun and have a clear view!
Also washed her and dusted the interior; it's amazing how dirty convertible interiors get, I really need to have mine detailed. The carpet is just gross.
Moonlight137 (11-26-2019)
#807
Car: 1990 Iroc, 1984 Buick Regal
Engine: 5.7, ZZ4 crate w/FIRST injection
Transmission: 700r4, 700r4
Axle/Gears: 3.73, 4.11
Put together a motor for my ‘89 GTA... I’m still waiting on a FIRST throttle body and fuel rails.
#808
Car: 1986 trans am
Engine: 305/350
me want,me want.....what are the specs on this beauty (especially the top end)
#812
I installed the replacement a/c blower motor. it is a marginal improvement. maybe my expectations for the system are to high? im not sure. I just feel like it should blow harder. I may pull the dash kick panel and check for leaks under there. see if im losing pressure or something.
#813
Nothing to the car but bought a supposedly NOS 86 OEM Firebird Service Manual off Ebay. We will see when i get it if its truly new
#814
The motor is a 355 with; GM performance crank, powdered metal rods, Keith black 2 relief flattop pistons, lt4 hotcam, 1.6 RR, heads off from my ZZ4 with a full port job, FIRST tpi, 24lb injectors, Scott Hansen programmed prom, Edelbrock TES headers (ceramic coated myself), and 3” exhaust.
#816
I need some help guys. I made a thread trying to get my a/c blower working better. im not getting a lot of answers. this isn't the place to ask tech questions but I would appreciate if you guys could check that thread and see if you have knowledge to drop on me. everything is working but it cant be correct.
im going to remove the top cover on the evaporator coil tomorrow and clean it as well as I can without removing it. if its totally trashed then I might remove it. I just don't want to empty my Freon that I just put in but if it has to be done than it does.
#817
You do realize that the faster you blow air through the cold thing, that there is less time for that air to get cold.
Slower through the core will make the air cooler.
#818
#819
#820
#822
Car: 1986 trans am
Engine: 305/350
i got a service manual with the 88 gta i just bought(the one thats 2 inches thick,is that the one?)
either for parts or ill just keep it.im still up in the air about it.it has 2-3 small rust spots,but realistically is pretty clean.
no accident damage and two long term owners.anyway it has a set of ceramic coated headers,an aluminum drive shaft,
a set of cross-lace gta rims with ws6 center caps,L98 TPI running decently,700R4 rebuilt,complete grey cloth interior,
wrap around aero spoiler,aftermarket deck,amp,sub box.plus its loaded other than t-roofs(thank god)
#823
Car: 1986 trans am
Engine: 305/350
i just bought this 2 weeks ago for $900.should i blow it apart or fix it?(i know the pics are crap,they were from the ad on kijiji- canadas craigslist)
1986BANDIT (08-13-2019)
#825
#828
Car: 1986 trans am
Engine: 305/350
thanks,its loaded .its got surface rust on the rear end and suspension components but i only see a couple spots on the body.
the one on the rear quarter,drivers side is a scrape and not a hole at all,its actually minor.i was leaning towards blowing it apart
but its a tpi 350 loaded gta with about 150,000 km.digital dash,tilt,cruise,wheel controls,air,power mirrors,windows,dorr locks.
headliner mint,dashpad mint,spoiler mint.
#829
Car: 1986 trans am
Engine: 305/350
ive got an 86 ta and its way cleaner underneath than this car (i wish it was the other way around tbh)
but im going to try and get a better look,i looks like a spot is rusted through right by the damned strut
tower(not a good place to weaken).a couple on the floor too but the under floor and sub frame structures
/braces look solid
/braces look solid
#830
Car: 1986 trans am
Engine: 305/350
i "borrowed" the wheels for my t/a.wish the GTA looked like this car.also wish i didn't live in a town house with a single garage.IN CANADA(snow will be coming in nov/dec)
#831
/braces look solid
/braces look solid
Rust bullet brushed on and seam sealed
Low VOC professional bed liner.
Rust cut out
Sound and thermal deadener
Patch panel ready to weld
Carpet in
1986BANDIT (08-15-2019)
#833
Engine: 5L TPI
Transmission: WCT5
/braces look solid
/braces look solid
#835
Car: 1986 trans am
Engine: 305/350
if i had this much room i would get myself in trouble or have a really immaculate car after doing what you are about to do!!!
#836
Ya I'm in the process of putting up shelves to put parts on lol. I got this 86 iroc few weeks ago. First project for a hobby. Honestly feel like I have 20 things on the go right now... interior is out, couple holes in the floor pans, t roof a little rusty, now finally these fenders will be off (bolts holding them on to the nose were seized and just spun so the nose had to come off with them lol
#837
Car: 1986 trans am
Engine: 305/350
If i can give you one piece of good advice Ive learned the hard way,try to pick one thing you want or need to do
and do it as complete as you can BEFORE doing anything else.this way you focus on one thing and follow through with it.
also take tons of pictures when taking something apart that's got tons of different fasteners,bag and label them too if you can.
makes things really easy when you go to put it back together.i just picked up a 1988 GTA a couple weeks ago myself and
ive got a decent 1986 trans am already,the price was just too good to pass up.im not trying to tell you what to do,just a suggestion...
my gta:
1988 gta $900
my gta:
1988 gta $900
#838
All suggestions and ideas are good. Yup I definitely have sandwich bags on the go for fastners. I also need to prioritize better. Thanks for the input. Nice car btw.
1986BANDIT (09-28-2019)
#840
Car: 1986 trans am
Engine: 305/350
stay at it and it will come together!! im up to having owned 6 third gens now,i always had camaros before(4 cylinder,6 cylinder,305 v8 berlinneta and the L98 350 v8 iroc)
but now im all about the firebirds,they seem to follow me home,lol....
#841
started removing parts to clean out the a/c evaporator. I got stuck though. I thought removing the bolts would be the hard part but I didn't have any trouble. once the top cover was loose I couldn't get it out. its a few inches under a lip on the firewall and I cant get it out. im probably going to have to remove a bunch pf crap..
#842
started looking for a new rear end. im looking for a 3.23 gear.
#844
Car: 1987 IROC Z
Engine: 5.7 TPI
Awesome intake - I am running a TPiS big mouth with siamesed runners now.... I would be interested to know how you like it after its tuned and operational. Nice Work
#846
installed a new chip from F-body. after I ordered it I got to thinking about it and resigned myself to expect no improvement with the ship. at the moment my car is a stock 305. I was pleasantly surprised that I did notice a difference. I only drove it a couple of miles but it seemed to run up the rpms a bit quicker and had a bit more pep. I will always take some extra pep. im hoping to get some rear end gears next. really want 4.42s but I run the expressway all the time and feel like 3.23 will be a better fit for the way I drive.
#847
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I installed a Hypertek chip a few years back and had the same feeling. It holds the shift points a little longer also. I bought a used one for $50 from a member here.
#848
today I got a 3.23 posi rear end. its from a 90k mile car. the gears look great. we tested the posi with a torque wrench and it worked well, it needs new wheel studs. I will freshen it up over the next couple of weeks and get it ready to go in.
