what did you do to your thirdgen today?
Old Aug 12, 2017 | 07:50 AM
  #51
Drew's Avatar
Re: what did you do to your thirdgen today?
About a thirty foot burnout. One or two of them.
Old Aug 12, 2017 | 08:29 AM
  #52
Abubaca's Avatar
Last year I replaced both window motors. PS window was fine, but the DS seemed to want to bog down about 2/3 of the way up. Marked all the adjustments, but apparently they were wrong. Started over and got it all adjusted properly. PITA....but...it works great now!
Old Aug 12, 2017 | 02:29 PM
  #53
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
Originally Posted by LiveIt!
Reinstalled my repaired fender, beat a dent out of the hood and put 22 stitches in the front end. she'll get around and have some fun but so much for going to that car show in the morning
I say still go to the show. you can SHOW them what it looks like when your car gets hurt and has to go to the hospital.
Old Aug 12, 2017 | 02:31 PM
  #54
Evilokc's Avatar
Engine: tbi 305
nice!! its wet here so I have been drifting around corners all day. lots of fun
Old Aug 12, 2017 | 02:33 PM
  #55
Evilokc's Avatar
Engine: tbi 305
I'm sorry whats ds?
Old Aug 12, 2017 | 04:00 PM
  #56
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Finished my valve cover replacement today. Used ProForm black crinkle, cast aluminum and the Chevy logo engraved and painted red. I used the Fel-Pro silicone gasket you have to stretch over the VC before you install it. I was worried it would fall off as I pried on that damn harness but it did not.
Old Aug 12, 2017 | 04:28 PM
  #57
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
That's a nice looking tpi
Old Aug 12, 2017 | 05:09 PM
  #58
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Haha thanks, you convinced me to go but it was 7am this morning and I was pretty worn out from third genning all day yesterday
Today I gotta reattach the front end to the fender and reattach the side Ground FX, then I'm all ready to
Old Aug 12, 2017 | 10:54 PM
  #59
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I'm sorry whats ds?
DS = Driver Side
PS = Passenger Side
Old Aug 12, 2017 | 11:10 PM
  #60
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
got mad at a stuck bolt. eventually got it out and celebrated
Old Aug 13, 2017 | 08:59 AM
  #61
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
yesterday I replaced the vacuum canister that I broke the vacuum nipple off of a couple months ago as well as put on a front ground effect thats in better condition than the one that was on the car.
I then went to put on a thirdgen non airbag wheel to replace the 1978 Trans am wheel the P.O put on but ran into an issue with the horn. the 78 wheel pushes down on the horn cam canceller thing while the new wheel needs a special wire to connect the two. anyone ever ran into this?
Old Aug 13, 2017 | 09:16 AM
  #62
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
I painted rims black, painted spiller black, took off passenger side fender to fix the lower mount as previous owner had crushed it and it rotted, making the fender bulge out a lot. It's now lined up. Just need to finish sanding and painting where the door molding use to be and the body is some what set!
cant seem to find the right Arctic white for my car; its a 91.
Old Aug 13, 2017 | 05:22 PM
  #63
Evilokc's Avatar
Engine: tbi 305
I bought new bolts for my ground effect and went to install nd they don't fit. are the body bolts specialty? I decided to not be dumb so I got out my calipers and measured the original bolt that was left in the remains of the ground effect. its 6mmx28mm body screw. I'm searching but not finding 6x28 but 6x25 seems to be the most common size. I'm going to order 30 fro $8 and will go from there.
Old Aug 13, 2017 | 06:19 PM
  #64
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
i actually was trying to find what this connects to today
Old Aug 13, 2017 | 06:48 PM
  #65
TylerSteez's Avatar
Engine: 383 stroker
o2 sensor
Old Aug 13, 2017 | 09:10 PM
  #66
Evilokc's Avatar
Engine: tbi 305
Originally Posted by TylerSteez
o2 sensor
is your car running rough? without the o2 sensor hooked up it would.
Old Aug 13, 2017 | 09:11 PM
  #67
Evilokc's Avatar
Engine: tbi 305
the black wheels with the raised white letter tires look really good. has a race look to it.
Old Aug 13, 2017 | 09:21 PM
  #68
Evilokc's Avatar
Engine: tbi 305
beautiful engine bay man.
Old Aug 14, 2017 | 07:13 AM
  #69
vinny R's Avatar
Car: 1991 Z28
Thank You! I have taken a lot of time over the past 2 yrs, cleaning and painting the little stuff. That is the original engine and has never been out of the car. I made a series of cleaning brushes of different sizes that I attached to wood dowels. I was able to get in those small areas and clean the 25+ yrs of dirt and grime.
Old Aug 14, 2017 | 08:27 PM
  #70
LiveIt!'s Avatar
Drove to school, battery died AND car overheated limped home, hoping Cheby is OK :c
Old Aug 14, 2017 | 11:42 PM
  #71
Evilokc's Avatar
Engine: tbi 305
battery AND overheating? what a $hit day. battery is nothing. can really only be a couple of things. the overheating is a pain. I just dealt with it myself. I ended up with 2 new freeze plugs, water pump, hoses, thermostat, and finally a radiator. good news is my car no longer overheats and I wont have to worry about any of that for years to come. good luck. let us know what sup when you diagnoses.
Old Aug 14, 2017 | 11:43 PM
  #72
Evilokc's Avatar
Engine: tbi 305
drove to work. its about 40 miles on the highway. I really enjoy the drive home.
Old Aug 15, 2017 | 10:43 PM
  #73
Evilokc's Avatar
Engine: tbi 305
drove to work. I'm stoked that my heat/defrost works so well after my heater core replacement. with he weather we`ve had the defrost has been great early in the morning.
Old Aug 15, 2017 | 11:00 PM
  #74
LiveIt!'s Avatar
Nice job on the heater core
I got home dead tired and fixed my fan to run with key ON, also troubleshooted alt a little bit. Even if she needs a jump start tomorrow she won't be overheating
Old Aug 19, 2017 | 01:36 PM
  #75
Evilokc's Avatar
Engine: tbi 305
I received the body bolts to install the front ground effect and the new i.a.c plug. so these will go on today. woot woot. I really hope the i.a.c plug soothes out the idle.
Old Aug 19, 2017 | 01:56 PM
  #76
89RedBurd's Avatar
Car: 89 GTA Trans Am
Engine: 5.7L L98
Axle/Gears: Factory 10 bolt with Stock Gears
Started on a basic tuneup and now ordering bushing for next weekends project.
Old Aug 19, 2017 | 01:57 PM
  #77
Evilokc's Avatar
Engine: tbi 305
plugs, wires only?
Old Aug 19, 2017 | 08:26 PM
  #78
89RedBurd's Avatar
Engine: 5.7L L98
Plugs, wires, cap and rotor, filters and fluids.
Old Aug 19, 2017 | 10:37 PM
  #79
Evilokc's Avatar
Engine: tbi 305
I got out today and installed my front p.s. ground effect. I couldn't get the bolts to screw into the speed nuts. I ran to the parts store with seconds to spare before they closed. I need to back each bolt out one at a time and add a little thread lock. I had a part vibrate off my motorcycle last week and now I'm paranoid.
Attached Thumbnails what did you do to your thirdgen today?-thumbnail_20170819_213552_resized.jpg   what did you do to your thirdgen today?-thumbnail_20170819_213558_resized.jpg
Old Aug 19, 2017 | 10:40 PM
  #80
Evilokc's Avatar
Engine: tbi 305
I noticed today that there is a spot on my frame where the tire rubs when its turned all the way. I plan to go back to stock wheels in the future so I'm not too worried about it right now.
Old Aug 19, 2017 | 10:59 PM
  #81
89RedBurd's Avatar
Engine: 5.7L L98
I put some draglites on my firebird a while back and they look pretty sweet. After I do some body mods I plan on dipping them black and doing a matte red vinyl wrap on the car with some matte black graphics. The mock ups so far look WICKED.
Old Aug 20, 2017 | 11:02 AM
  #82
Evilokc's Avatar
Engine: tbi 305
I kind of like the wheel tire combo that's on the car now. the tires are big and fat but if they don't fit they don't fit.
Old Aug 20, 2017 | 12:34 PM
  #83
89RedBurd's Avatar
Engine: 5.7L L98
When I bought my car it had S10 Extreme wheels on it that just looked god awful so the first chance I got to replace them I did. Don't miss them one bit.
Old Aug 20, 2017 | 08:28 PM
  #84
Evilokc's Avatar
Engine: tbi 305
soldered on a new i.a.c plug to replace the broken one. I then started looking at the hi speed fan issue. nothing looked burnt but I did see that the hi speed relay locking clip was broken. i went and bought a new one and when I pulled the relay off it had a ton of grease in it. like the p.o had broken the relay clip then put some grease in it to keep it plugged in . there was also some disintegrated electric tape. I get that this wasn't his favorite car. it was clearly neglected but to half *** simple stuff that keeps the car from working is dumb. I installed the and relay and now have hi speed. I'm going to have to either replace the hi speed relay plug or find some way to epoxy a locking clip back on. I strapped it down with a couple of zip ties for the time being. its gonna be nice to have hi speed a/c tomorrow. it gets hot here.
Old Aug 20, 2017 | 08:42 PM
  #85
Evilokc's Avatar
Engine: tbi 305
my gas cap has been leaking. I meant to replace it a while ago and kept forgetting. I filled my tank Friday and on the way home gas spilled down the side of my car. enough was enough. I bought the replacement and when I swapped them out I found out what the problem was.. HONDA MOTOR COMPANY!
Attached Thumbnails what did you do to your thirdgen today?-thumbnail_20170820_201111_resized.jpg
Old Aug 21, 2017 | 11:03 PM
  #86
Evilokc's Avatar
Engine: tbi 305
drove to work and on the way home had to turn down the a/c. I was proud.
Old Aug 21, 2017 | 11:15 PM
  #87
89RedBurd's Avatar
Engine: 5.7L L98
Mine still has the original R12 in it and it blows so cold that it'll make Miley Cyrus put her clothes back on. lol I'm gonna hate it when it runs out.
Old Aug 21, 2017 | 11:26 PM
  #88
rbrackett's Avatar
Stood in the front yard and watched the eclipse...lol
Old Aug 21, 2017 | 11:38 PM
  #89
Robbie_S's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Axle/Gears: Currie 9"/US Gear Lightning 3.00
I would call today a success!
Today was a good day. Front brakes and springs installed. Just posted a quick update on my build thread.
Old Aug 21, 2017 | 11:40 PM
  #90
rbrackett's Avatar
Well....after the eclipse, I drove the TA to get more beers. That was a success!
Old Aug 22, 2017 | 08:29 AM
  #91
Evilokc's Avatar
Engine: tbi 305
I'm going to have to check out your build thread. I have been thinking about upgraded springs.
Old Aug 24, 2017 | 06:31 PM
  #92
Evilokc's Avatar
Engine: tbi 305
does the third gen have a gas light? if it does mine doesn't work. I ran my car out of gas right at the gas station. I was the first car in the left turn lane that would have let me pull right in the 7/11 and the car died. I had to leave the car at the light while every one honked. did I mention it was 5:30 and the traffic was crazy? 7/11 did have one gallon gas cans for $14.99!! i put a buck of gas in it and walked back over to the car. by this time there was 15 cars behind me that had missed 3 lights. they were so pissed. i put the gas in and started the car and pulled into the gas station and all is well. $14.99!! for a gas can! are you serious? what jerks! love my firebird though.
Old Aug 26, 2017 | 10:53 AM
  #93
Robbie_S's Avatar
Car: 1989 Iroc Z
Engine: 5.7
So, what is everyone going to be doing with their cars this weekend?
Old Aug 26, 2017 | 10:54 AM
  #94
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Wash wax burnouts
Old Aug 26, 2017 | 10:59 AM
  #95
Robbie_S's Avatar
Car: 1989 Iroc Z
Engine: 5.7
Wash wax burnouts
In that order?
Old Aug 26, 2017 | 12:55 PM
  #96
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
got both heads on waiting on new cam, cleaning and painting parts
Old Aug 26, 2017 | 05:45 PM
  #97
Evilokc's Avatar
Engine: tbi 305
what cam are you going to use instro84? you going top end or low/midrange?
Old Aug 26, 2017 | 10:13 PM
  #98
2 birds 1 Z's Avatar
Car: 2002 Firehawk & ws6 1989 Iroc Z
Engine: All 3 have 350s
Transmission: Birds manual Iroc auto
Axle/Gears: TAs 342 & Iroc who knows?
Thought basically all day about the '89 Iroc that I'm taking delivery of tomorrow. 10 AM. Then it's gonna sit in storage for about 6 weeks, until I get another vacation & get it registered.
Old Aug 27, 2017 | 08:34 AM
  #99
Evilokc's Avatar
Engine: tbi 305
thats pretty exciting 2birds. I bought mine by accident on ebay and it took a month to get it delivered. I hadn't seen it in person.
Old Aug 27, 2017 | 08:59 AM
  #100
Same here. Only the ad online has 35 pics & a walk around vid. Good enough for me. Have always wanted an Iroc & finally bit the bullet. I currently own a 2002 Trans Am ws6 & a 2002 TA Firehawk as toys. The Iroc will be the same. Needs a new head liner, both arm rests & the rear bumper top is a bit dull. Also there is a strip about 6" wide that runs from the rear glass to the spoiler that is dull, too. You can see it in the vid as he walks around the right rear. All of these issues will be addressed to bring this car to show quality. http://www.ebay.com/itm/1989-Chevrol...-/391863421944 This is the walk around. Scroll down to the larger 3/4 rear shot & click on that for the vid. Love the blue stripe on black.
