How do I check my egr?
Old Jan 2, 2002 | 06:19 PM
craiger's Avatar
I recently posted that i have a code 32 after my engine swap. The only mods I have are AFR 190 heads with the heat risers and a little bigger cam @.050 208/222. Why am i getting a code 32? and how do i check the egr?
Old Jan 2, 2002 | 07:06 PM
ede's Avatar
ede
easy way to check is to reach under it and stick a finger in the slot and push up on the diaphram, if you can get a finger into it. if not you can pull a vacumn on it with a hand pump. if it "works" correctly it'll make the engine stumble when you push the diaphram. depending on engines there maybe a selonoid that works the egr that may be bad causeing it to open at the wrong time or too much for too long.
Old Jan 2, 2002 | 08:44 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
I would like to change my EGR valve, just because it is original and not that much money, but with the TPI, it looks like a real pain in the nut sack to get to.
Mike
jklein337
Sep 19, 2018 06:23 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
Out-Cast
Aug 17, 2015 10:57 AM
