battery gauge reading way high
Old Sep 18, 2017 | 02:17 PM
Nateo09's Avatar
Want a title? Post!
have a 2007 duramax with the LBZ. Last winter when it got cold the battery gauge in the cab was pegged at 19 so I took it to the chevy dealership and they said the alternator was good but the batteries were bad so they replaced them then a couple months later it happened again but a few days later it went away. Now the other day it got to like 40 degrees and did it again so I took it to the auto shop to have them test the alternator again but again it tested good and one of the batteries tested bad. I then took it home and checked them myself and when the truck is off they are at 12.5 and running they are at 14.5 so they are fine. Anyone have any idea what the deal is?
Old Sep 18, 2017 | 05:35 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: battery gauge reading way high
Nate , if your dashboard gauge is reading 19 volts but a known accurate voltmeter is measuring 14.5 at the battery when running then I'd say your dashboard gauge is doing what most of em do , giving inaccurate readings . Some read high , some read low , but I'd trust an accurate meter (such as a "Fluke" VOM , for instance) to tell me the real truth and if the readings differ then I'd likely disregard what the dash gauge says .
Now with that said , this is a board for 1982 through 1992 Chevy Camaro and Pontiac Firebird cars only , 1982/1992 being the third generation of the GM "F" body platform . All questions about any other makes/models are usually locked and the person is given directions to a forum more suited to their make/model of car , What in the Hell IS a "Duramax" anyway ?
Old Sep 19, 2017 | 08:51 AM
Jorlain's Avatar
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
A GM 6.6L Diesel.
Old Sep 25, 2017 | 11:37 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
2007 is the third gen chevrolet diesel engine. Makes sense, thirdgen.org right lol
Old Sep 26, 2017 | 08:04 PM
OrangeBird's Avatar
Car: 1989 Firebird
Originally Posted by Jorlain
A GM 6.6L Diesel.
Thank You for the answer Jorlain , and sorry I missed your post till now
It's funny , whenever I hear "third gen" I automatically think of our cars , without giving a thought that just about all car/truck models had several generations of design changes . I know I may sound picky here , but I truly don't think any other variant of our cars (first , second , fourth gen , etc) had quite the same good looking profile that our cars have
spyder1
May 3, 2017 09:23 PM
230 firebird
Mar 21, 2017 12:20 PM
91Z28_Nightmaro
Dec 18, 2016 12:22 PM
RockinRandall
Dec 1, 2016 05:08 PM
