intake 7121
Re: intake 7121
The booster port is usually on the carb, not the intake. Most carbs provide it.
However, if you want one on the intake, just drill & tap a hole in the plenum, and screw in a fitting. 1/4" pipe thread is the best option for the hole. Make sure wherever you drill it that hoses lines etc. are clear of any carb linkage and stuff like that.
Re: intake 7121
Yes it is, but be careful, it may be underneath the carb's secondary fuel bowl.
Try before commit.
Use the one on your carb if it has it.
Try before commit.
Re: intake 7121
Thanks for the warning didnt think of that, I have been searching the entire web to try and get a diagram of a elderbrock performer rpm intake to show what all the connections are for and would really help a novice like me
Re: intake 7121
I shoulda paid more attention:
That intake fits a Frod. This site is for 3rd gen Camaro/Firebird. Your post doesn't belong here. Maybe somebody on a Frod board that knows more about Frods can give you more help.
newbvetteguy
Alternative Port EFI Intakes
54
Jun 2, 2020 04:31 PM
[WI] 89 tpi intake
88 350 tpi formula
Feb 27, 2017 07:13 PM
85TransAm406
Nov 1, 2016 08:43 AM
padak
Sep 25, 2016 12:41 PM
