Taller Tires
Old Jan 3, 2002 | 12:05 AM
85_ZED28's Avatar
Car: '85 Z28
Taller Tires
Will taller tires decrease the gear ratio?
Is it a significant difference in performance?
thanks for any help!
Old Jan 3, 2002 | 12:26 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Yes, and it all depends.....
tall skinny tires are way better in the snow
Old Jan 3, 2002 | 12:30 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: Taller Tires
Going with shorter tires is said to be the poor man's gear change. I forget which summit issue, but there is a way to calculate your new gear ratio by changing tire sizes. By getting taller tires the gear ratio decreases numerically but you have a higher gear ratio, which will worsen you acceleration.
Old Jan 3, 2002 | 01:40 PM
85transamtpi's Avatar
Just adding to Marks statement...in most cases it will increase top speed and gas mileage.
Old Jan 3, 2002 | 01:53 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
it works just like chaning the gear (you can calculate it by percentage)
Just as a 3.08 is ten percent higher than a 3.36, a 27 inch tire is ten percent taller (and hence larger in circumference) than a 24.5.
Tire diameters can vary up to about .5 inch between companies. In some cases, you can change the net effect of a rear end ratio by approximately 5 percent by investigating the various tire options.
A 4.10 can be made to act like about a 3.9 with a little bit of work.
InfernalVortex
Apr 20, 2021 11:31 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
