non 3rd gen - 99 jeep cherokee
Old Jan 3, 2002 | 04:14 AM
rezinn's Avatar
My mom had a brake job done to her jeep a few weeks ago. Resurfaced rotors and new pads. Ever since then at low speeds when the car is warm you can hear and feel a bumping coming from the front right side. Last week I took the wheel off and it turns out that they guys did not even torque down the lug nuts right.. they couldn't have been over 40ft/lbs. I didn't see anything unusual when I went in there, but I torqued the bolts back on and she took it back to them the next day to complain(Just Tires). They couldn't hear it and said nothing was wrong, but the problem persists. Any ideas? Could they have screwed up the rotors while resurfacing?
This was the first thing ever done to the car by someone other than myself, rotors had never been turned until now.
Old Jan 3, 2002 | 10:52 AM
snakeskinner's Avatar
re
not much experience on the cherokee's but many FWD fords have a problem with rust scale buildup between the rotor and the hub and between the wheel and the rotor. take the wheel and rotor off and use a wire brush or wire wheel and clean all rust scale off then reassemble with the proper pattern and torque on the wheels. I know grand cherokee's eat rotors like candy so you may just want to get some new ones if it's that bad.
Old Jan 3, 2002 | 06:07 PM
rezinn's Avatar
turns out they screwed up when they turned it.. had to do it again and it seems fine now. Thanks for the help.
ex-x-fire
Jan 12, 2024 01:58 PM
Caspar
Jun 19, 2016 11:19 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Cacike
Aug 27, 2015 05:10 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
