ZZ4 Cam with 1.32 inch ZZ4 springs
Old Jan 3, 2002 | 10:16 AM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
Do you think this would work fo rme? They arent 1.44inch springs but they would be new. There is also another cam for cheaper that is the SAME EXACT one except it has a LSA of 109*, would that be bad for my computer? The ZZ4 cam ahs a LSA of 112*, what would you guys think? With some new ZZ4 push rods also.
Old Jan 3, 2002 | 11:18 PM
GSXMEN's Avatar
The ZZ4 springs will work just fine with either cam. Just make sure you have enough clearance between the bottom of the retainer and the top of the guide with the seal on it.
Which heads are you going to run?
Scott
Old Jan 4, 2002 | 12:04 AM
BuddyLeeX's Avatar
stock heads
Old Jan 4, 2002 | 08:43 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
springs n/p - 109lsa ? problem
You better have a very short overall duration. Like 205-208 intake at 050 or you will probably not go closed loop.
lt500r55
Sep 1, 2021 01:30 PM
Street Lethal
Apr 30, 2019 12:14 PM
italiano67
Dec 11, 2016 09:21 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
