305 and a 350
Old Nov 9, 2017 | 09:41 AM
Spygrip's Avatar
Want a title? Post!
305 and a 350
Question. Can I swap over my TPI Intake from a 305 to a 350 ? Is their anything I need to do the 350?
Old Nov 9, 2017 | 11:53 AM
Re: 305 and a 350
Yes, year for year.
In 87 the angle of the center 2 intake bolts on each side was changed, except in Vette (aluminum head) 350s. So the rule is, 87-up intakes fit 87-up non-Vette motors, and 86-back and Vette intakes & heads fit each other.
You can slot the intake bolt holes and use angle washers to overcome this.
Also the Vette heads lack the exhaust crossover and therefore that adds another minor detail of difference.
Old Nov 9, 2017 | 11:56 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 and a 350
The vette base also has a rear coolant crossover. You need larger injectors 22#hr over the 305’s 19#hr.
You also need your memcal reprogrammed to a 350 calibration.
Stock Car 46
Jul 29, 2018 12:08 PM
Stock Car 46
Camaros Wanted
Jul 7, 2017 10:08 AM
pgs
Mar 15, 2017 02:33 PM
myslo50
Feb 14, 2017 02:56 PM
bensbaby
Nov 1, 2016 06:44 PM
