Vortec L31 emissions
Old Nov 14, 2017 | 05:49 AM
KCG's Avatar
KCG
Car: 89 IROC
Has anyone passed a tailpipe/sniffer test in their state with a Vortec head engine swap?
If so, could you post your results please?
Old Nov 14, 2017 | 07:13 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: Vortec L31 emissions
Vortec heads have nothing to do with passing a sniffer test.
What are you really asking?
Old Nov 14, 2017 | 08:36 AM
KCG's Avatar
KCG
Car: 89 IROC
Well, actually they do. The Vortec heads have no provisions to route exhaust gas thru the intake.
So the question is does anyone have test results from a Vortec headed engine with no EGR set up on it?
Old Nov 14, 2017 | 08:40 AM
86LG4Bird's Avatar
OK, now I understand where you're coming from.
That would be a factor for cold startup emissions.
Sniffer tests should be done on a warm engine. You didn't say factory/EPA cold startup testing.
It's a non-issue.
Old Nov 14, 2017 | 11:02 AM
KCG's Avatar
KCG
Car: 89 IROC
Yeah I'm just asking if anyone's passed a sniffer test with no EGR setup.
I don't know exactly when EGR is active. From what I read its not at idle or WOT. So cruise/part throttle is when its active?
The test I have to pass is at idle, and again at 2500 rpm.
'89 IROC in this case.
Old Nov 14, 2017 | 04:03 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
My 1983 G20 van with a TPI Vortec 350 blew practically ZEROS on the emissions tests and that was with exhaust cooling Tri-Y long tube headers before the cats.
Old Nov 14, 2017 | 05:17 PM
KCG's Avatar
KCG
Car: 89 IROC
So no EGR rigged up?
Would you happen to have the results you could post?
Old Nov 14, 2017 | 06:35 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
No EGR hooked up and it was disabled in the tune. No air injection either.
Old Nov 15, 2017 | 04:26 AM
KCG's Avatar
KCG
Car: 89 IROC
Awesome, THANK YOU!
Anyone else?
Old Nov 15, 2017 | 09:40 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Pretty much. EGR effectively lowers the size of your engine by letting in "air" without much, if any, oxygen. So the intake charge that is coming in combined with the EGR gas has total less oxygen for the volume, so you can inject less fuel. It's not for emissions as much for economy
Old Nov 15, 2017 | 09:48 AM
86LG4Bird's Avatar
EGR also lowers NOx by reducing peak combustion temperatures at cruise.
Although even without EGR, Fast355's results above show only 2-3% of allowable NOx !
Old Nov 15, 2017 | 04:59 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The EGR is more an emissions device but happens to help fuel economy in some applications. My Express van got better mileage with the EGR disabled. From the factory the Vortec 350 uses very little EGR at crusing speeds. The valve has a much higher opening % under acceleration at part-throttle than steady cruise.
