identifying a disconnected blue wire
Old Nov 16, 2017 | 02:27 PM
mike32506's Avatar
Car: 1984 T/A
Engine: L69 5.0L 4BBL H.O.
Transmission: 5 Spd
Axle/Gears: Stock
Hello, I took pics of a disconnected blue wire that was (to best of my knowledge) never connected yet the car previously ran without any error code. It exits a loom just next to the PCV valve and no obvious place to connect it. This is a 84 T/A with a Quadrajet. Only wiring for the carb I'm aware is choke, throttle position sensor and mixture control solenoid. Anyone has an idea, I appreciate it. Thanks
Mike
Attached Thumbnails identifying a disconnected blue wire-20171116_133700.jpg   identifying a disconnected blue wire-20171116_133736.jpg
Old Nov 16, 2017 | 03:02 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: identifying a disconnected blue wire
That Go's To The Idle Stop Solenoid.
Old Nov 16, 2017 | 03:38 PM
mike32506's Avatar
Car: 1984 T/A
Transmission: 5 Spd
Axle/Gears: Stock
Thks gt4373. Long story short, the Idle Stop solenoid was in a plastic bag when I received it back from the rebuild shop. just now putting everything back together and didn't notice they left the part off. My bad. Many thanks for your help!!
