LB9 wtih world products 58 cc heads. Fan switch and temp sending unit adaptors
Old Dec 8, 2017 | 03:20 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Does anyone have suggestions on fittings that would properly integrate the cooling fan switch and temperature gauge sending probe into the holes drilled into world products cast iron heads? I am about to install a set of new heads and the stock sending units and fan switch are too small for the holes provided in my new after market heads. I am interested on how other members may have solved this problem without causing the cooling fan switch, or temperature gauge sending unit to stick out too much and interfere with the exhaust or oil dip stick.
Thanks in advance for your suggestions.
Old Dec 8, 2017 | 04:16 PM
Re: LB9 wtih world products 58 cc heads. Fan switch and temp sending unit adaptors
Hardware store or Home Depot kind of place... plumbing dept, brass fittings, 3/8" - 1/2" NPT (pipe thread) bushing. AFAIK there's no fitment problem, only adds about ¼" to the height.
Wolfman720
Jun 9, 2019 05:36 PM
91_rs-teal
Jul 11, 2015 12:48 PM
camarors88
May 5, 2007 09:20 AM
vernw
Jun 16, 2005 09:03 AM
ZRATED
Sep 11, 2001 09:08 AM
