whats wrong wtih my oil?
Old May 4, 2007 | 01:26 AM
camarors88's Avatar
ok, the other day my car was running sluggish, and i thought it was te maf sensor so i unplugged it hopeing that if it was, itd reset, well i went for a drive later on and car was overheating,(have a small leak in radiator i gotta get fixed) well any ways, the resivor was completely empty which it wasnt in the morning, and the oil dipstick wasnt even in all the way so i had no idea what to think, so i cleaned up that mess, and checked the oil, which was VERY hot lol, and thinking id need to add oil, instead on the dipstick it read that i had to much oil now? whats going on, i have no idea what to think....
Old May 4, 2007 | 08:15 AM
pairtoe's Avatar
Re: whats wrong wtih my oil?
what color was the oil?
Old May 4, 2007 | 11:02 AM
brad_26's Avatar
Car: 1984 camaro
Engine: 2.8l to 383 stroker
Transmission: t5 to th400
Axle/Gears: 12 bolt soon with 3.73s
did the oil look like a choclate milkshake lol ?
Old May 4, 2007 | 12:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
reads like someone blew a head gasket.
Old May 4, 2007 | 05:07 PM
camarors88's Avatar
well, it was the same color as the oil in my dads truck, so i have no idea, and it smelt like oil....kind of a light brown color
Old May 4, 2007 | 05:18 PM
kjvail1204's Avatar
Well let it set for a little while and check it again cold, if its has white in it then its probly the head gasket i wouldnt drive it anymore till you find the problem, lost of all water over one day, and how long ago did you change your oil
Old May 5, 2007 | 09:20 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
how much over full was it? Oil will expand a bit when it gets hot as almost any fluid will. so it may read Full cold, but be 1/4qt over when the engine is hot.
Oil gets up to the same temp as the engine block itself so it should get very hot. unless you have an oil cooler.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
Dyno Don
Jan 24, 2016 08:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
