1992 Camaro 305 Build Help!
Old Dec 18, 2017 | 10:25 PM
Crissy92's Avatar
Car: 92' Camaro
Transmission: 5 speed
Hello everyone I am new to thirdgen I've been searching for answers to my question but yet I cannot find them. I am looking to wake up the little 5.0 I have at the moment I will build a stronger bigger engine in the future but for now this will do. So I have a 305 tbi with the 5 speed manual transmission. I have an edelbrock intake I want to install and I want to know what all do I need to install from the bolts to the distributor (also is there a link that teaches how to install distributor) I am also installing a double timing chain, hooker headers with dual exhaust, bigger efficient water pump, aluminum radiator, new clutch and I already have 3.73 gears my main concern is what do I exactly need to do the intake swap.
Old Dec 23, 2017 | 05:54 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: 1992 Camaro 305 Build Help!
Is the manifold you have for a TBI or carb?
Should be able to just reuse all of the bolts and hardware unless you want to get a bolt dress up kit
As for the distributor the best thing to do is to remove the cap and turn the motor by hand until the timing mark is at 0 and the rotor in the distributor is pointing at #1 (5 O'clock position). Once it's in this position you can remove it and will be able to reinstall it per the oem instructions.
Check youtube for videos on installing sbc intake manifolds to get a visual instruction.
92z28rockinmaro
Members Camaros
36
Jan 22, 2013 04:04 PM
flyin89
Mar 20, 2009 09:11 PM
85_Camaro_Kid
Theoretical and Street Racing
50
Apr 9, 2006 05:15 AM
musicmanz28
Jan 23, 2005 11:18 PM
