Help with lift.
Old Dec 27, 2017 | 06:44 PM
91GTABIRD305's Avatar
Car: 1991 Pontiac Firebird Trans Am GTA
Engine: 5.0 TPI
Transmission: 4 Speed Automatic
Help with lift.
bought a pair of 083 heads today for a decent price. I have a comp cams 12-422-8 cam which I want to throw in my rebuild. The lift looks to be barely too big for the stock head. What do I need to do to accommodate for these? Here is the specs.
Cam Style:Hydraulic roller tappet
Basic Operating RPM Range:1,600-5,400
Intake Duration at 050 inch Lift:218
Exhaust Duration at 050 inch Lift:224
Duration at 050 inch Lift:218 int./224 exh.
Advertised Intake Duration:270
Advertised Exhaust Duration:276
Advertised Duration:270 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.495 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.502 in.
Valve Lift with Factory Rocker Arm Ratio:0.495 int./0.502 exh.
Lobe Separation (degrees):110
HasseO
Aug 13, 2016 07:21 PM
tapwr
Oct 10, 2015 08:53 AM
chuck6860
Jul 23, 2002 09:36 AM
nesluopetan
Feb 13, 2001 02:28 PM
