These heads fit? Will the work?
Old Jan 4, 2002 | 08:23 AM
BuddyLeeX's Avatar
Car: 06 Toyota Tundra SR5
"Bare 487 casting heads have been cleaned and reconditioned and cut for 2.02/1.60 valves-make offer"
Will they ft, Im buying them for 200$
Old Jan 4, 2002 | 10:11 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
They will bolt on, but you don't want them for two reasons:
1) The 2.02 valves will come very close to the cylinder wall on a 305, making them ineffective due to shrouding.
2) They have 75cc chambers, which will kill compression on a 305, even if shaved down as thin as possible.
You'd be better off with 416's with porting work and 1.94 intake valves, or World S/R Torquer 305's.
Old Jan 4, 2002 | 12:18 PM
BuddyLeeX's Avatar
"CHEVY #416 CYLINDER HEADS. THEY HAVE THE 1.84 1.50 VALVES. THEY HAVE BEEN HOT TANKED AND BEAD BLASTED ON ALL SIDES AND PORTS. THEY ARE OFF OF A 305 H.O CAMARO ENGINE AND WAS RUNNING WHEN PARKED. THEY HAVE THE 58cc COMBUSTION CHAMBERS AND 150 cc INTAKE RUNNERS"
Would these work?
Old Jan 4, 2002 | 09:23 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
They should work. Are they going on your 87? If so remember that they are perimeter bolt valve cover, and the center intake bolts are at a different angle than your stock heads. Also if they have been bead blasted...wash and blow out with air several times. Those beads hide in there and are hard to get out. I've had them get into the oil, and so has a friend of mine. The glass beads will raise hell with your bearings and lifters.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
matthew911
Aug 12, 2015 09:38 AM
milk
Aug 10, 2015 06:26 PM
