Procedure for changing fuel injectors
Old Jan 4, 2002 | 01:46 PM
BlazinOR's Avatar
I looked all over the tech article section and didn't see a definitive recap on how to change injectors. I realize it's not rocket science but there has to be some 'look out for's' and 'watch for's' in doing this.
Anyone have an article on how to do this - I know basically what do to but are there tricks about the retainers, etc. that I should know about?
Thanks...........
Old Jan 4, 2002 | 10:16 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
There's the obvious stuff...i/e remove cables, pleanum, runners...thing to look for on the runners is that there is a bolt going through the backside of the runners...easy to miss until you've looked it over.
Fuel rail clip need to be rotated, I forget which way, but it'll be obvious when you do it.
I pull the rails with the injectors intact first..wiggling up a little bit after a squirt od WD40 into each hole. ONce the rail assy is up and out, I'll take the injectors out.
Not too much of a suprise anywhere.
Old Jan 5, 2002 | 12:56 AM
rezinn's Avatar
Check your same post on the tpi board.
specialized
Jun 18, 2022 09:26 AM
bryan623
Mar 22, 2021 06:43 PM
jklein337
Sep 19, 2018 06:23 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
