Alternator overdrive pulley. will this one work
Old Jan 20, 2018 | 04:12 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
i have a 1986 trans am and was looking into getting an alternator overdrive pulley but was wondering on the shaft bore size as ive been seeing different sizes. I was looking into a march one, part number MCH-110-08 from summit, but would like to know the diameter size of the shaft so I get one that fits properly. or if the one I am looking at will work can someone please confirm to see if it will fit and work. thank you.
Old Jan 21, 2018 | 02:19 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Alternator overdrive pulley. will this one work
I think it should be the standard 17mm, so it should work.
That one on summit is made for the full serpentine belt system though. That's not what 1986 fbodies came with.
Old Jan 21, 2018 | 07:03 AM
Twin_Turbo's Avatar
I use cv products pulleys they are super small for the small diameter crank hub drives. They do take only a small 3 rib belt though.
https://rover.ebay.com/rover/0/0/0?m...2F182717371935
Old Jan 24, 2018 | 10:54 PM
happyhapka's Avatar
hmm I guess I cant find one that will work with my set up than. unless someone can point me to the right direction. I called and the guy said it would work so I ordered it. how shitty is that.
Killert
Jul 21, 2010 07:12 PM
gpierce
Jun 17, 2002 03:33 PM
82z28122
Carburetors
May 17, 2002 09:03 PM
ChattyCaprice
Feb 17, 2002 04:47 PM
menace88SC
Carburetors
Dec 24, 2001 09:24 AM
