stewart stage 2 water pump
Old Jan 20, 2018 | 06:50 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
will this work for my 86 tpi trans am? part number 23123. it says in the description that its for 87 and up... so not sure if it will work. just want to confirm.
thanks
Old Jan 20, 2018 | 08:22 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: stewart stage 2 water pump
If you compare part numbers for 86-87 on RockAuto they use the same pump. Reverse rotation didn’t come until 88 iirc with the serpentine setup.
Old Jan 20, 2018 | 08:34 PM
happyhapka's Avatar
ok thanks... I was looking at the 23113 as the blades or for Counter Clockwise which is the direction it goes. I was hoping that the style itself will work. I noticed that the 23123 is counter clockwise which will not work. so I believe I need the 23113.
Old Jan 21, 2018 | 01:48 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
IMO easier to get the older short pump and use the pump extensions. Your 86 goes clockwise like all the older ones.
Old Jan 31, 2018 | 03:59 PM
happyhapka's Avatar
ok so short or long? Which one should i get.... or does it matter
Old Jan 31, 2018 | 04:51 PM
Engine: Lb9
Transmission: M20
Long, if you can get one.
Old Jan 31, 2018 | 05:49 PM
happyhapka's Avatar
thanks
Old Feb 1, 2018 | 07:55 AM
happyhapka's Avatar
where do you get the pump extension. just wanna look at it. there's no problem with it leaking?
Old Feb 1, 2018 | 10:58 AM
Engine: Lb9
Transmission: M20
https://m.ebay.com/sch/i.html?_nkw=c...er+pump+spacer
You would need a 2 3/8 spacer. I didn’t see any one making them.
Old Feb 1, 2018 | 11:04 AM
Engine: Lb9
Transmission: M20
Are you thinking of a fan spacer ?
Old Feb 1, 2018 | 09:29 PM
happyhapka's Avatar
No sir.. i was just curiouse didnt know what he ment about it... guess i didnt realize the difference between short and long.... if our cars take the long ill get a long.
LT1FUN
Jun 1, 2009 01:53 PM
black_highway
Apr 17, 2007 09:59 AM
25THRSS
Aftermarket Product Review
Jun 18, 2004 08:08 PM
david auster
Jun 12, 2004 12:12 AM
