Unknown Camshaft
Unknown Camshaft
Hey ladies and gents,
I am currently in the process of putting a Big block Chevy in my 92 Camaro and I got a good deal on the motor. It cam out of a pickup truck with some things done to it but for the most part unknown. It has springs and roller rockers and a cam. While looking over the motor I pulled the rear cam plug to get a number off the camshaft and after searching all over the internet I cannot find who makes this cam or any info on it. If anyone knows anything about it that would be great. It’s a mark IV 454. Attached are pictures of the markings on it.
[img]webkit-fake-url://611efb62-e249-4a59-9ba2-85e68a917c7b/imagejpeg[/img]
[img]webkit-fake-url://e2d152bb-fbcf-4e06-8cf3-2dcf2470d31f/imagejpeg[/img]
Re: Unknown Camshaft
Camshaft Type Lobe # 5646
Rated Duration 275
Duration in Degrees @ .050 248 @ .200 145
Lobe Lift .266
Tappet Lift @ TDC 106° .106 110° .093
Theoretical Valve Lift @ "0" Lash Rocker Arm Ratio Ratio 1.5 .399 1.6 .426 1.7 .452
http://www.compcams.com/Technical/Ca...obeCatalog.pdf
See page 40.
Rated Duration 275
Lobe Lift .266
See page 40.
Or is that number 3848 ?
Pull up that pdf, go to the top of the page, click EDIT, then FIND, type in the correct number and see what you get.
Thanks for your help! that's exactly what I was thinking that it was 3848. I couldn't find anything under comp cams with it and the others from comp I have seen have different markings on the back. I'm not sure if anyone has seen one like this or know what brand it is. it looks like it also has 13-45-02 and a sideways M on it.
green_is
Jun 13, 2001 02:52 PM
