Do I stick with my engine or not?
Old Feb 15, 2018 | 09:48 PM
marcus25's Avatar
Car: 88 Camaro Iroc Z
Engine: 383 SBC
Transmission: 700r4 600hp, 650 lbs-ft
Axle/Gears: 3.27 9 bolt posi
I have an 88 Camaro iroc z that has no powertrain at the moment. My current Camaro is an 85 with a 305 in it but it has 350 heads and "upgraded" fuel injectors. I am torn between keeping my 305 or buying a 350 because I will stroke either one with a 383 kit. The cost between the two is about $100 difference. Im not looking to make 500+ hp; just want to make somewhere between 300-450 hp and a max of 480 lb torque. My 700r4 will hold up to 650 hp and 600 lb torque so a drivetrain is not an issue. All I want to know is can 305 block withstand that kind of hp if so, I'll probably go 305 for convenience; if not, then I know a guy with 3 350s for me to look at. Remember Im not looking for a 11 second build, just want something to put in the car so I may sell my 85 but I want more power than what Im making now which i dont know but im confident its 200+ hp already but not near 300.
Old Feb 16, 2018 | 05:53 AM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Re: Do I stick with my engine or not?
the 305 will hold up just fine
Old Feb 16, 2018 | 09:05 AM
cardo0's Avatar
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
If your just going to flip the car then any motor that doesn't smoke will do the job and your wasting money rebuilding. Most pick a part boneyards will have a guarantee on their $200 used motors. Hard to beat that.
Good luck.
88gunmetalgta
May 21, 2012 01:32 PM
gearhead0384
Mar 11, 2010 01:44 PM
mattsv8_03
Oct 8, 2007 11:05 AM
PopaPork
Nov 18, 2000 08:07 PM
