how does a crank position sensor work?
Old Jan 5, 2002 | 12:08 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
if it's shot will the car still crank or will it crank and not fire?
ideas?
Old Jan 5, 2002 | 12:30 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It will crank and not fire.
The computer uses the CPS to detect where the crankshaft is in rotation. It the computer can't tell if the engine is cranking then it won't know what cylinder needs to be fired. Until it gets a CPS signal the computer thinks the engine is stopped.
Ford Powerstroke/Navistar engines are bad for that. It's the most common problem for a nostart complaint.
Note: I race against a Monza that looks like that.
Old Jan 5, 2002 | 12:46 AM
Engine: 305TPI
thanks Stephen
my Vega is a V8 project, should be a quick car.. my sig has a horrible pic but whatever
i'm thinking it's the CPS, too.. seems to be the most common problem that I've come across as well.. i've been reading FAQs on the net all night and 90% of them are the CPS
ttyl man!
colin
Old Jan 5, 2002 | 01:22 AM
FstBrd6point3's Avatar
jeeps are pretty notorius for the CPS to start to crap out early. My dad has 2000 grand cherokee with 65K miles on it, and the thing cranks and cranks before it finaly kicks over. and if U accidentaly stop and then start cranking again quick, it throws the timing out of whack and runs like **** until you reset the ECM. just my little addition lol.
Old Jan 5, 2002 | 02:08 PM
20-psi's Avatar
I had a belt alignment problem with my TTA and it would wear away the crank trigger sensor. Nothing like rolling down the highway and the car would just stop running.
Pete
Old Jan 6, 2002 | 01:55 PM
89Irocz23's Avatar
my dad used to have a 70 something vega which orignaly had a 4 cylinder and he put a built 350 in it. It sounded good it had side pipes on it and it ran low 12s also he had NOS to put I dunno how much. I just know this car was scary.
Caspar
Jun 19, 2016 11:19 PM
Jae992
Aug 27, 2015 09:07 AM
Thirim
Aug 13, 2015 03:09 PM
Tonyy_z
Aug 12, 2015 07:20 AM
