where does this wire go?
Was messing around with the O2 sensor on 91 305. Connection is on upstream side on drive side of block on the front end. I notice a single wire connector that is not attached. Did I accidentally disconnect this? Cant find what it would attach to.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: where does this wire go?
Non heated O2 sensors use a single wire.
Take pictures.
Take pictures.
If the wire is green, it's for the temp gauge sending unit. Look between the #1 & #3 spark plugs.
mr420joe
Oct 12, 2009 10:18 PM
RS'er
Car Audio
Mar 25, 2001 05:36 PM
