Looking for Borescope recommendations.
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Hi, I am looking to purchase a Bore scope, I would like a unit that is complete, not looking to use my phone or other device. This is not something I will be using all the time so I would rather not spend a fortune but I am also not looking for junk.
This is one of the ones I am looking at.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Looking for Borescope recommendations.
I use something very similar to this but I would recommend getting the HD version. The cheaper version with lower resolution isn't worth the cost saving. Even the HD version at 640x480 just isn't good enough.
https://www.harborfreight.com/High-R...der-60695.html
Search for "Inspection Camera" on ebay and pick one you like.
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Yes the ones that run off your phone are crap. I bought one from amazon, and its good enough to see down maybe into the dash a little, to pick up a lost screw. But if you want to look into a cyl head or any other really dark place, you wont see anything
Car: 86 Z28
The one I listed above from amazon has the same resolution as the HF HD for a lot less. I want a stand alone unit not one that hooks to the phone.
grafx
Jun 26, 2003 03:29 PM
