Driver's Side to Passengers Side Dip Stick Adapter
Old Apr 12, 2018 | 11:45 AM
Ja85z28's Avatar
Axle/Gears: 4:10
I need a little help; Remember back in the day when guys were putting drivers side dipstick blocks into mid-80's cars. We'd drill and tap the passenger side of the block for a dip stick adapter.
I don't think that adapter is available. What the chances that you have one in a junk drawer!
Old Apr 12, 2018 | 09:41 PM
NoEmissions84TA's Avatar
Re: Driver's Side to Passengers Side Dip Stick Adapter
Would this work?
http://www.jbugs.com/product/8932.ht...iABEgIBzvD_BwE
Old Apr 12, 2018 | 10:12 PM
Ja85z28's Avatar
Axle/Gears: 4:10
Not exactly what I am looking for, but options are good. Thanks
Old Apr 12, 2018 | 11:32 PM
Drew's Avatar
I think what you're looking for, are called "headers". At least that seems to be the most common solution to running an older block in a thirdgen. Personally, I'd rather run a later block since not only is the dipstick in the right place, but the flywheel and flexplates bolt up, the starters bolt up, the exhaust manifolds bolt up, not to mention that bitchin' one piece oil pan gasket and 1pc rear main seal, and centerbolt valve covers that don't leak...
I'd like to see an adapter though. Just for curiosity.
zacharyhorn
May 14, 2014 06:19 PM
gearhead0384
Mar 11, 2010 01:44 PM
Chopper_86
Aug 22, 2004 07:57 PM
