Ok found somting interesting, Help...
Old Jan 5, 2002 | 07:44 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Well first off, I started with the wires cap and rotor, All look like Sh*t, that is probably contributing to my problem.
Problem two, I pulled out plug number 4, and it had oil on it. Whats up with that? Is that good bad? What could cause that.
I'm workin on it right now
3.1 Camaro
Old Jan 5, 2002 | 08:23 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
oil can accumulate around the plug.
after the new one has been in a while pull it and see what it looks like. The only way to know 4sure is the do a compression test.
Old Jan 5, 2002 | 08:57 PM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
not necessarily..
my engine rebuilder says you can have good compression but still have bad oil control.. my Dad and I have good compression on our '72 chevy truck with a 402BB in it but it uses oil (has since the rebuild, uses a quart every 200mi)
the engine runs perfectly fine, and doesn't foul plugs..
the engine rebuilder says that if my Dad had incorrectly installed the rings it could burn oil but have good compession..
in your case, if you have fouled plugs that means cylinder wear unless your motor was just rebuilt..
btw: Dad's engine is coming apart in a few months, we'll find out then what happened
Old Jan 6, 2002 | 06:00 AM
ede's Avatar
ede
where's the oil at? on the deramic or oil fouling? if it's on the ceramic i'd say you have a leaking valve cover gasket on the eletrod end would be fouling, or maybe gas and you think it's oil. if it's inside the head it could be a dead or weak part in the ignition system not allowing it to burn everything completely.
hectre13
Dec 11, 2023 08:14 AM
gta90
Sep 15, 2015 04:00 PM
overdriv
Aug 20, 2015 03:52 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
