Gas Overflow Problem
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Hello,
When I first got the car this was an issue I faced, and still face now.
When I fill up my tank, mind you I let it go until it clicks off automatically. It SEEMS fine, but as I drive down the road I smell gas and then low and behold its coming out of the cap.
I've tried a new cap, to no avail. Should I try another? What could cause this issue, and how can I fix it?
Thanks in advance!
Thanks in advance!
Re: Gas Overflow Problem
Hello,
Thanks in advance!
Thanks in advance!
If it's a solid cap and it's leaking , and you've tried more than one (solid) cap , my next idea would be ; Has the tank been replaced ? The filler cap threads on many aftermarket tanks are said to be lacking , indeed the replacement tank in my car had problems with the cap threading down far enough to seat the rubber gasket and seal the cap , so much so that I was forced to "dress" the plastic threads of the cap with a file & sandpaper to get it to thread down far enough to seal properly .
A search may turn up threads where folks have dealt with this very issue , and from personal experience I will tell you your not alone ....
a1987formula350cu
Jul 31, 2000 12:15 AM
