Does a ford EEC IV TPI need to be grounded, i.e. why do they recommend dielectric sil
!(88 Ford E350 460 ci) no spark , all tests point to faulty module ( new from NAPA), used Artic Silver 5, instead of silicone as I thought heat transfer was reason for use of bonding gel) ?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Does a ford EEC IV TPI need to be grounded, i.e. why do they recommend dielectric
Found On Road Dead
Did you replace the pickup in the distributor? The pickup and TFI are supposed to be serviced in pairs. Usually easier to just get a remanned distributor.
Thirdgen.org is a 82-92 Camaro/Firebird forum. Check out a Ford truck forum.
IROCZman15
Jun 2, 2020 10:28 PM
