Ounces of R134a needed
Old May 12, 2018 | 02:50 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
In the car (1992) my system was bone dry and I don't have any labels on how much it takes. I've seen different responses on the amount (30, 40, 48).
I just emptied a 12oz and 19oz and its still cycling about every 5 seconds.
Old May 13, 2018 | 02:57 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Ounces of R134a needed
Stock '92 Camaro, label on A/C box states 2.25 lbs of R12.
RBob.
Old May 13, 2018 | 07:25 PM
Pro's Avatar
Pro
Car: 1992 Z28
Engine: 5.7 TPI
The parts store had 3.5 lbs in their system, and I had a feeling that was way off.
It's filled up, and I get fantastic cold air. But it still cycles every 5-7 seconds. The highside hovers around 175psi, and low eventually dips to 30 and shuts off.
- Replaced schrader valve in low side port
- Pulled a vacuum, and no leaks
- Replaced orifice
- Filled up the system
Greg
Dec 16, 2008 09:14 AM
johnsonm
Jul 9, 2007 03:40 PM
Dale
May 31, 2003 07:14 AM
squirrelybird
Jul 28, 2001 09:54 PM
