Which one is the fuel return line ?
Old May 14, 2018 | 03:06 PM
illuminati's Avatar
Hello guys I have a 88 Pontiac Firebird I'm doing the carb Swap and I just installed the three-way return style regulator for the fuel and I noticed that the back has no connection to the return line can anybody help me to determine which one will be the return line ? thank you
Old May 14, 2018 | 08:05 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: Which one is the fuel return line ?
Old May 14, 2018 | 09:17 PM
NoEmissions84TA's Avatar
You get bonus points for using fuel-injection hose clamps.
You did notice the disconnected line near your UFO???
It also looks like only half of your UFO is there.
2 of your fuel lines are looped together.
Old May 14, 2018 | 09:32 PM
zed-028's Avatar
thats an alarmingly good point...
Old May 14, 2018 | 10:45 PM
illuminati's Avatar
what is that UFO thing used for?
I had put a in tank fuel pump to the 3-way return style regulator. turn the power on the bird and smelled gas and follow it to this spot and now i know that thats the return line pouring out fuel so im going to follow the lines from the top of the tank on down and use one of those lines to make a vent for the tank aswell .
thanks guys
Old May 14, 2018 | 11:49 PM
It is a 2-way valve. It is supposed to let air in as gas is consumed,
AND release excess pressure should it build too high (safety).
Normally the vapors are supposed to go to the charcoal canister and
get burned by the engine when started. There should be a canister purge valve
or solenoid near the canister. You most likely have the solenoid controlled by the ECM.
https://www.thirdgen.org/forums/tpi/...ml#post6066121
https://www.thirdgen.org/forums/tech...mell-when.html
Old May 15, 2018 | 07:56 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
thanks guys
The return line on the sender is the only one to go to the bottom of the tank. If there is some gas in the tank blow into each of the unknown lines with the gas cap off.
The one that causes the gas to bubble is the return.
The one that has a restriction in it is for the CCP system.
The one that has no restriction and causes no bubbling is for the UFO/mushroom valve.
RBob.
paulldove@live.
Carburetors
26
Nov 16, 2015 06:12 PM
MTCAMARO
Carburetors
Mar 11, 2010 10:34 AM
sj85ta
Carburetors
Mar 18, 2007 09:58 PM
Phoenix1987
Jul 21, 2006 09:54 AM
Duke901
Apr 23, 2003 11:34 AM
