return line or no return line
Old Mar 18, 2007 | 07:39 PM
sj85ta's Avatar
Car: 1985 Trans AM
Engine: 305 HO
Hi I have been reading for awhile on here to try and find this answer but have had no luck I will be installing a Holley Red electric fuel pump in my 85 TA for my switch to carb and removing the old intake pump because it does not work. what do I do with the return line should I get a regulator with a return or just block it off ? I know by reading here that the other line that use to go to the canister can be feed out by the fender.What have you guys done
Old Mar 18, 2007 | 08:43 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
It will be alot easier on the pump to run a return line rather than 'dead heading' the thing.
Old Mar 18, 2007 | 09:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The Holley red has an internal bypass, so you could omit the return line. Running a return-style regulator at the engine would help keep fuel temperatures down, though.
Old Mar 18, 2007 | 09:21 PM
sj85ta's Avatar
Car: 1985 Trans AM
Engine: 305 HO
when you say omit does that mean block it off or just take it out from the tank as I will be dropping the tank this next weekend and I need to know what to do with all the lines comming out of the tank? Hope that is not a stupid question as I am learning all this here as I go.just updated my info so you could see that I am also from Canada.
Old Mar 18, 2007 | 09:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
he meant to run a dead head style regulator.
But like ape said, running a return style reg will help to keep the fuel cooler from the circulation...
Old Mar 18, 2007 | 09:38 PM
sj85ta's Avatar
Car: 1985 Trans AM
Engine: 305 HO
I have a mallory 4309 regulator I bought awhile ago before I found out the pump in the tank was no good should I run that with the holley red to my edelbrock 1406 carb.
Old Mar 18, 2007 | 09:54 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you've got the regulator already, you might as well go ahead and use it.
Old Mar 18, 2007 | 09:58 PM
sj85ta's Avatar
Car: 1985 Trans AM
Engine: 305 HO
OK thanks for all the help you guys have been great
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
TBRays98
Sep 6, 2015 05:05 PM
