87 GTA a/c low press switch question
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
If I remove the a/c low pressure switch on an 87 GTA, will the R134 leak out? Or is there a valve inside that will prevent it from leaking out??? Thanks in advance!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 87 GTA a/c low press switch question
No. Pressure switches have a schrader valve in the fitting that they screw on to. It's like a tire valve core so the pressure switches can be replaced without evacuating the system.
