My engine is heating up !
Old May 27, 2018 | 06:09 AM
miche25's Avatar
Car: Camaro 1984
Help me please, My engine is heating up, I changed my thermothat, I checked my water pump by manually turning my pulley manually and it works. However, when the gas pedal gives it a few strokes, the liquid does not seem to circulate in my system. My antifreeze is in good condition.
Old May 27, 2018 | 06:52 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: My engine is heating up !
Put a pressure tester on it and make sure your system does not have a leak somewhere. If you are not holding pressure the water will not flow properly. Also how old is your water pump? I have seen old pump impellers rust and the fins become smaller and don't pump as much as they should.
Scubatankeater
Mar 3, 2007 02:26 PM
71Camaro-Norway
Jun 28, 2006 09:13 PM
1991tealRSt-topGuy
Apr 28, 2003 06:57 PM
