Engine over heating
Old Feb 1, 2007 | 11:42 AM
Scubatankeater's Avatar
Engine over heating
Well I'm buying a 89 camaro, but it has an over heating problem, water pump works, oil pump works, but it just over heats, so I'm guessing its part of the engine's knocking noise, thoughts?
Old Feb 1, 2007 | 12:09 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
If the pump works then my first thought would be to check the radiator fluid level (sounds dumb, but you have to start small when addressing issues with cars).
Next I'd check to see if hte fans are kicking on at 210 degrees (i believe it's around that temperature). If the fans dont kick on, well theres your problem, and It probably lies within a bad fuse or relay. Also check wiring, and even the motor of the fan itself could be shot.
If THAT isnt the issue, i'd try a stock oem water pump from autozone or something.
My fans werent working, but I was unhappy with the temp they come on at anyhow, so I rigged up a manual switch to the inside of my car, and I keep them on all the time. Now my car always stays between 160-190.
Old Feb 1, 2007 | 12:51 PM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Check for the air dam underneath, commonly overlooked but without it you will have overheating problems. And I have ripped one off a couple times (damn snow).
Old Feb 1, 2007 | 01:28 PM
^^ Ah, thats a good one, forgot about that. The air dam is a long strip of plastic about 5" tall that scoops air into the radiator. It is black, and underneath the front of the car, reaching from passenger side to drivers side.
Old Feb 1, 2007 | 01:29 PM
weeoh5's Avatar
if the motors knocking and it overheats...i'd point to head gasket...probably has compression getting into the cooling system. You could do a chemical test to see if there is combustion gasses in the coolant but if its knocking already..the damage is done
Old Feb 1, 2007 | 05:38 PM
jcisthechamp05's Avatar
Car: 1987 IROC-Z
You might also want to check to make sure the thermostat is working, or just swap b/c it is a cheap part....If the engine isn't letting the hot water out to flow to the radiator then there is you problem. Another simple solution, is make sure the pressure cap on the radiator is still in order b/c if it isn't functioning properly, it will show symptoms of overheating, and maybe you just don't realize it could be somehting as simple as that.
Old Mar 3, 2007 | 02:05 AM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
Is it that important? I tore mine off because half of it was sagging (literally torn off anyway) and dragging on the ground.
Old Mar 3, 2007 | 02:35 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
Grim, you can have problems overheating on the freeway. That air dam forces air through the radiator cooling the water/coolant inside. You will have a lot less air going where its supposed to without it. Hope this helps.
Scuba, does it overheat on the street? sitting still? or on the freeway? or all of the above?
like already mentioned: I would check to make sure the coolant is full in the radiator, that the fans are coming on, and go from there. Good luck.
Old Mar 3, 2007 | 03:20 AM
Grim'91Z's Avatar
Engine: L98 5.7L V8
If that's the case I'm gonna see if I can rig it back up (I kept the dam). Maybe drill new holes and prop it back up. No wonder my engines gets to 240* in under an hour of driving.
Old Mar 3, 2007 | 02:26 PM
Upshotunity's Avatar
Car: 1988 Camaro
Engine: 5.0L TBI
The car will survive with out the air dam but it is preferred.
Skubatanker start off little like they said.
Check fluid- best bet would be to flush the entire cooling system.
170 Thermostat- suggested earlier, might as well when you flush.
also you may want to check ******* total fan control post.
cheap and easy fix for these fans turning on so late, thats why the engin gets so hot.
Two fans I think the primary turns on at about 220* and single fan turns on at about 245* about. Which obviously is no good.
Hope this helps.
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
