AS&M runners attention Traxion or any with experience
Old Jan 6, 2002 | 01:55 PM
Gta-Paladin's Avatar
Are the insanely high priced semi siamesed large tube runners worth it? I mean will i honestly be able to justify the amount these runners cost? Traxion, a little mouse told me you had these before you switched over to miniram.
Old Jan 6, 2002 | 08:03 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have had them for about a year. Can I say it improved my car? Well going stock to the edelbrock base and asm runners i picked up a .10th. I wished I would have bought something else.
Old Jan 6, 2002 | 08:05 PM
Is it possible they flowed too much? Or that u couldnt hook up with them?
Old Jan 6, 2002 | 08:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
i'm not sure, I picked up some TF heads and a nice cam and will be putting them in soon. I hope that the runners will perform. The ASM runners are already extrude honed and they are a very nice piece. i also got better gas milage. they coulndt hurt.
Old Jan 6, 2002 | 08:11 PM
For the whole tpi setup what can i upgrade to and what would you suggest?
Runners - i'll go with as&m
Throttle body - 52mm Holly?
Base???
What else can be upgraded in order to run better times
Old Jan 6, 2002 | 10:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
A nicely ported Edelbrock base, AS&M Runners, Ported Plenum and the stock TB should be good. Heck the new 502 Ram Jet uses the 48mm TB. Nice set of header and a Cat Back would be good. Lots of people go for the flowmaster or the hooker but I went with the Edelbrock Catback and I Love it. The Pipes are AL And the muffler is Stainless steel and the whole system comes with a lifetime warrenty. A homemade Cold Air System would be good. I performed it on my Formula and that had to be one of the best mods. I have left my chip stock because when I tried the stage 2 Fast Chip from ed write it was horrible. Stay with a 180 or 195 T-Stat I have found from going from a 160 to a 180 there was a big differance in power for me at least.
Old Jan 8, 2002 | 06:57 PM
Thanks mkos... Anyone else on the runners?
Linson
Oct 24, 2025 02:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
Royal_Z
Sep 30, 2015 08:45 PM
drumstixer
Sep 29, 2015 03:02 PM
