Restrictor Plate
Old Jan 6, 2002 | 03:14 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Restrictor Plate
Do you guys think it would be possible to build a restrictor plate for my car to place under the 1" carb adapter. I would like to know if this would work to increase gas mileage, or if distribution problems would be created. The reason is ask is i am going to drive across country and would like the best gas mileage possible.
Also what other ideas do you have for increasing mileage, short of trans or motor swap.
Old Jan 6, 2002 | 03:33 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
Re: Restrictor Plate
no
yes
keep your foot out of it.
Old Jan 6, 2002 | 04:15 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you want better gas mileage, swap to a Q-jet, if you need rear tires soon, wouldn't hurt to run some slightly talller tires to reduce your effective gearing as well. Make sure all your tune-up parts are fresh, as well as timing set correctly, clean air filter, etc. Wouldn't hurt to experiment with a little less timing and 87 octane gas as well to reduce costs. Synthetic oil has shown me some mild gas mileage increases as well.
Old Jan 6, 2002 | 05:12 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
what really killing u is the 3.73s and what i would imagine is a non-lockup350
the taller tires will help... but they will really need to be 28+ inches. Try to find an OD gear somewhere.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
