Crank but won't start
So I have an 89 Camaro RS 2.8l v6 it hasn't started for couple years. Replaced the fuel pump, fuel relay, and filter still no start then replaced spark plugs. So the car has spark and also fuel pressure. Need help any thoughts
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Crank but won't start
Could be one of two things. Does your car key have a pellet in it ? (Vats).
Or your ignition control module is bad. Do you have spark ?
Btw you are posting in the wrong section. If a moderator shuts down your thread start a new one in the v6 section.
tippyjeep
Mar 10, 2012 09:14 AM
rbrooks
Mar 3, 2010 11:50 PM
Free Bird
Feb 15, 2005 01:11 PM
