Idle and th700r4
Idle and th700r4
hello, I'm new here. I am in France. I own for a few years a pontiac firebird of 1991 with a GM 3.1 v6 engine.
For some time she has asked me a problem and I need your help.
my idle becomes very unstable when I'm in deceleration with the car. she even manages to stall.
Otherwise the idle works very well, and I have no hole or loss of power during acceleration.
imagine, I roll and then I release the accelerator to stop, it will start stalling then the regime goes up, and so on until the vehicle is stopped.
The gearbox could produce this problem? it's a th700r4 it gets me together.
the problem does not appear when, slowing down I go to neutral, and it seems to me that this only happens when I'm on my gear lever in overdrive position.
then gearbox or engine?
Thanks for your help.
Car: check
Engine: check
Transmission: check
Re: Idle and th700r4
If you have recently disconnected the battery or unplugged the ECM, need to do an idle learn procedure. On the V6 board here on TGO do a search using my user name and idle + learn for the keywords.
There are a couple of threads that outline how to do an idle learn.
RBob.
RBob.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
327_TPI_77_Maro
Carburetors
Apr 21, 2006 12:51 AM
FocusGhia
May 26, 2004 08:55 AM
Matt87GTA
Sep 18, 2001 11:55 PM
