TH700R4 filter and gasket same as 4L60E?
Old May 19, 2004 | 05:59 AM
FocusGhia's Avatar
Car: 88 Camaro IROC T-Top - Gunmetal Grey
Engine: 305 TPI V8
This weekend I'm going to change the transmission fluid in my TH700R4 box.
I ordered a new filter (which comes with the pan gasket) from an american car parts supplier over here (UK) for £13.87
I have a nagging doubt in my mind though.
I told him I had a TH700R4 and the car was an 88 IROC 5.0 TPI.
But he's sending me the kit for a 4L60E gearbox and says as mine is an overdrive box and is basically the same as that one the filter and gasket are the same.
I know they're supposed to be the same box, jut one is electronic, so in theory he's correct. Especially as his parts catalogue lists the filter and gasker for a TH700R4 up to 87 and this 4L60E filter and gasket for 88 onwards.
And as mine is an 88 I see his logic.
Can smeone confirm that the filter and gasker for the TH700R4 form 88 on is the same as the 4L60E?
Old May 19, 2004 | 09:00 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
They should be the same.
Old May 19, 2004 | 09:24 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Yes they are exactly the same filter.
Old May 20, 2004 | 06:29 AM
FocusGhia's Avatar
Engine: 305 TPI V8
Lovely.
I'll give this a go at the weekend then (and do the engine oil and coolant while I'm at it).
Old May 21, 2004 | 01:21 AM
Pro Built Automatics's Avatar
The 4L60E filter is different, the pan gasket the same.
Old May 21, 2004 | 06:03 AM
FocusGhia's Avatar
Engine: 305 TPI V8
The invoice shows TH700 so I should be ok I recon.
Only one way to find out...
Old May 21, 2004 | 11:31 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Pay attention, probuilt already told you that the filter is DIFFERENT... It is.. you need the right one.. Not for a 700R4..
Old May 21, 2004 | 01:34 PM
FocusGhia's Avatar
Engine: 305 TPI V8
Er...
But I have a 700R4???
Old May 21, 2004 | 03:39 PM
thirdgen88's Avatar
Car: 1995 Corvette
Gotcha.
Old May 24, 2004 | 06:34 AM
FocusGhia's Avatar
Engine: 305 TPI V8
Hehe.
Fitted it yesterday, bit fiddly getting the gasket lined up as there is a crossmember in the way of the pan. But all done.
Box shifts quicker now and at wide open throttle will get into 3rd as soon as I lwet off the throttle, instead of the revs needing to fall to 3,500. It still won't xhange from 2nd-3rd at WOT though.
Checked the tv cable, pulled it all the way back as far as you can, pressed the throttle cable but no clicking. It didn't adjust itself at all.
Even fully pulled back the cable is slack at zero throttle, but tight at full throttle.
As it doesn't click (ie doesn't adjust) and is slack at zero throttle i assume the cable needs replacing...
Old May 25, 2004 | 07:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
When you say "pulled back", you mean the cable is in towards the firewall, and not pulled out towards the radiator, right?
Old May 26, 2004 | 08:11 AM
FocusGhia's Avatar
Engine: 305 TPI V8
Pulled back towards the firewall (ie the cabin), not forwards.
I can pull it back until the black (plastic?) bit is flush with the bracket, ie as far back as you can possible pull it. At this point the actual steel wire is still a little slack.
Then when I release the D button and go into the car and press the throttle down the cable doesn't ratchet forwards at all although on full throttle the steel wire is tight. Coming off the throttle the cable is still slack of course.
Old May 26, 2004 | 08:55 AM
TA5LiterHO's Avatar
I have used 2 different gasket and filter kits from Advance Autoparts that say 700r4 and 4l60e on the same box. Thats probably what the confusion was.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
R13_Braz
Sep 18, 2015 05:00 PM
blackandblue02
Sep 10, 2015 08:19 PM
hdis2002
Sep 8, 2015 02:52 PM
