HELP!!! Code 42 (EST)
Old Jan 6, 2002 | 05:12 PM
Nitroburn's Avatar
Ok... I've racked my brain on this one. To give you all alittle history, it's a fresh built 305 with mods listed in my sig (except for the Ignition box). I'm getting code 42 (Electronic Spark Timing) and not sure exactly where to look. I have checked the EST connector next to the right strut tower and I have also replaced the EST Module (the one that's on the driver's side firewall) with a new one. Still getting the damn code!
What else should I check? The Chilton's manual doesn't even cover what to check on this code.
I have not had this on the road yet because I need to clear all the codes before I get it smog'ed tested so I have no idea about the performance. However, I do notice a little hesitation when I crack the throttle quickly.
Thanks everyone!!
Mike
Old Jan 6, 2002 | 10:27 PM
rezinn's Avatar
Have you reset the computer since you set the timing? The codes will stay if you haven't.
Old Jan 7, 2002 | 01:31 AM
craiger's Avatar
EXACTLY! If you set your timming and unplugged the brown wire...which you must to inoreder to get the timming right, you will always get a code 42. Now, all you have to do is DC your battery for 30seconds and you will no longer have the code 42
Old Jan 7, 2002 | 04:27 AM
Nitroburn's Avatar
I did reset the computer. I let it sit for 7 days without a battery in it. If that didn't reset it....I don't know what will!!
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
