Good time to replace the motor mounts?
Old Jul 3, 2018 | 05:13 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
All;
I'll shortly be putting a T56 in my '88 IROC...
I was looking at the motor mounts, and wasn't too pleased at what I saw.
Would it be a good time to replace them while the transmission is out of the car, or will that really make much of a difference?
I was thinking since there would be less weight to deal with, it might be a good idea to tackle them while the car is in the air, and the drivetrain is lighter.
Thoughts?
Old Jul 3, 2018 | 05:15 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Good time to replace the motor mounts?
Yes perfect time.
Old Jul 3, 2018 | 05:21 PM
Whenever they are questionable, it's the perfect time.
Old Jul 3, 2018 | 06:13 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
While the transmission is out, you can hoist the motor a little bit easier.
Obviously, you need to lift the motor about an inch to slide the old mounts out, and slide the new mounts in.
You are STILL going to have to figure out how you are going to work around the CONTROL ARMS to reach the bolts that go from the motor mounts into the K-member. Unbolting the motor from the motor mounts is the easy part. Removing the old motor mounts from the K-member is the hard part.
Getting around the control arms is really the biggest challenge of replacing motor mounts on a third-gen. Whether the motor is still connected to the transmission is a far less-significant factor.
89lsxtransam
LSX and LTX Parts
Oct 27, 2011 06:40 AM
Black Z28
Sep 11, 2009 04:51 PM
gregbr
Mar 18, 2005 04:56 PM
xpndbl3
Jan 10, 2003 10:16 PM
427camaro
Feb 22, 2002 06:16 AM
