69 350 block, 89 350 heads
Old Jan 6, 2002 | 05:48 PM
Dans91's Avatar
Car: 91 RS
would 350 heads off of a 89 iroc z-28 fit onto a 69 350 block and then would the edelbrock TBI intake (with EGR) fit onto the 89 350 iroc heads.
thank you much!!!!!!!
Old Jan 6, 2002 | 05:59 PM
GreenProStreet's Avatar
Not sure about the TBI, but unless the manifold comes with the heads the heads wont fit on the classic. 87+ changed the manifold to head bolt patterns.
Old Jan 6, 2002 | 06:09 PM
ede's Avatar
ede
the heads will fit the block and the intake should fit the heads, i think ( not 100% sure).
Old Jan 6, 2002 | 07:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That combination of parts will all bolt up.
OBTW re. your other post:
The knock sensor goes into the coolant drain hole in the pass side of the block, instead of a regular pipe plug. All small block Chevy motors have had the same hole in the same place with the same thread (1/4" pipe) since 1955, so you won't have any trouble with a knock sensor.
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
BBSDesigns
Aug 11, 2015 07:39 PM
