Keep breaking starter!
Old Jul 12, 2018 | 12:04 AM
xXCKAXx's Avatar
Car: 1989 Firebird Formula
Engine: Chevy 383 ProFlow XT fuel injection
Transmission: TH400
I have a 89 Formula with a mildly built 350. In February of this year, I bent a push rod and put my car down for a while. About a month ago I got t up and running again, but when I first tried to crank it over, I heard this horrible grinding sound from the starter. I went to look underneath and the cone cracked. I did that to 3 more oe style starters. I purchased and mini starter and shimmed it appropriately, it work for a little bit but then it look led like the teeth would get stuck in the flex plate until eventually it would spin with out engaging. After that I purchased a high torque starter and that worked for a while as well. Until recently it started grinding again... I have no clue why it keeps doing this. Any ideas on why and how to fix this problem? It has become extremely frustrating
Old Jul 12, 2018 | 05:29 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Keep breaking starter!
Your three most likely possibilities are ;
#1 Despite your best efforts your still not getting them shimmed quite right ,
Or
#2 Your not using the correct starter bolts ,
Or
#3 The holes in your block are drilled wrong and this has the starter an an improper angle that no amount of proper shimming can cure .
If you do a search of this board you will find that #3 is not as outrageous a possibility as it sounds , several threads have in fact dealt with this exact problem , starter holes fractionally off from where they need to be , and for your sake all you can do is hope like Hell your problem lies somewhere with answers #1 and #2 above .
Old Jul 12, 2018 | 06:36 AM
If this is a 70s 350 block such as a 010 casting, it's drilled wrong, and you need another block.
Search the site for my userID and the phrase "The Starter Problem" including the "The". I've described it, and some of the other 70s factory sloppy block machine work Problems, in detail, many times over the years.
Blackened
Apr 28, 2024 09:55 PM
OWGTI
Jun 27, 2009 01:43 PM
CSwanson
May 23, 2002 09:37 AM
Neil
Jul 1, 2001 06:22 PM
87-305
Jul 31, 2000 10:49 AM
