Camaro 1986, 2,8 problem with engine
Hi guys from heart of europe
I have camaro 1986, 2.8 multiport FI. I could start but no power and no speed if I stepp on the gas pedal.
I replace:
sparg plugs (ngk 2771)
Ignition control module (ACDelco D1943A)
pickup coil
ignition coil (UNITED MOTOR PRODUCTS C535)
Catalytic converter is ok (replaced some years ago)
and no change
Diagnostic say only 34-MAF (but this sensor is bad some years and car was run good)
Engine running video: I try test fuel presure and seems ok. video: (its quite loud, I remove catalytic converter)
Any idea where is problem? Thank you for reply and sorry for my english
I replace:
pickup coil
and no change
Car: 1992 Z28
Engine: 5.7 TPI
Axle/Gears: G80 3.23
Re: Camaro 1986, 2,8 problem with engine
Do you have access to a scan tool? And can you do a backpressure test? If youre flooring it and RPMs do not rise like they used to then something could be plugged. Also youre english is good.
I know you don't want to hear this , , , BUT , proper troubleshooting procedure literally demands that you repair the known faults first , before you go chasing your tail looking for a malfunction that just may well involve the code 34 ! There are various levels of MAF failure , as in perhaps when the first code 34 appeared some years ago the MAF voltage output was slightly low , enough to trigger the code but not low enough to affect the running of the engine . Now , some years later maybe the MAF has finally totally failed , no output whatsoever , and this very well could cause the issue your now experiencing .
The new MAF may well or may well not solve your problem , but like I said earlier , before blindly throwing one more random part at the car , fix what you KNOW is broken first , and then if the problem persists then take the troubleshooting from there . If a new MAF doesn't fix it , as a next step put a "noid light" on both injector banks (after checking the fuses INJ 1 and INJ 2) , to make sure all 6 of your injectors are actually spraying fuel into the engine .
PS , Before you DO replace the MAF , using this handy wiring diagram for your engine make sure you do have +12V on the light blue wire coming from the MAF relay
Last edited by OrangeBird; Jul 21, 2018 at 10:46 AM. Reason: To add wiring diagram .
Pro: No, I have no scan tool, what you mean exactly? Is some better for my old camaro, than MIL(service engine light and plug wire between A and B pin on the diagnostic conector)?
Same with "backpressure test".. but I try use google for more info
OrangeBird: I understand you, but real sittuation is: MAF was totaly dead some years ago(interupted wire on PCB - no signal to ECU ) and camaro was run in safe mode good. The problem is new.
All fuses are ok, but I try check the injectors.
Today I noticed on the back side of throttle it too much carbon with oil or fuel(carbon is not dry but greasy). Same in manifod intake - I try disassemble it and cean.
If I start engine and unplug conector from TPS sensor, RPM will increase 2x or 3x (i dont know exactly, i have no tachometr) and engine run pretty good (on this RPM)
I make video with cold start.. Is here Before star(after keys move to ON position) is heard creak sound(same if I turn off the engine).. what can it be? fuel regulator? Stepper motor is silent and sound comes out of that place somewhere.
Car: 1992 Z28
Engine: 5.7 TPI
It sounds like you just have a code reader. You need a scanner with an ALDL cable.
You can get one complete unit like this:
http://www.1320electronics.com/products.html
And then sync it up with your phone/tablet. Start up the car and check out your fuel trims, O2 sensor readings, etc.
Or you can get an ALDL cable from moates.net, tunerpro rt (free), and a laptop and do the same. But the first link I posted would get you started quicker.
Thanks, I look at it.
Is some chance that the software will be work with this scaner+reduction cable?:
scaner elm327: https://www.aliexpress.com/item/ELM3...ceBeautifyAB=0
reduction ALDL-OBD2: https://www.ebay.de/itm/Diagnosegera...QAAOSwdzla~oYP
I buy elm327 one year ago for my ford. Reduction I can buy from a neighboring country.. It will be about 2 weeks faster.
CamaroPaul
Aug 23, 2013 12:37 AM
lesterrobinson
Dec 8, 2005 09:38 PM
